Monster Panel - MySQL integration
Monster Panel gives you the ability to integrate with an install of MySQL. The purpose of this article is to give you step-by-step instructions on how to integrate your MySQL instance with Monster Panel.
How to integrate with MySQL
RECOMMENDED: Try creating a database before proceeding with the following steps as Integration may already be configured.
  1. Login to Monster Panel
  2. Navigate to the “Server Manager”.
  3. Navigate to “Database Services”.
  4. Click “Add Database Service”.
  5. Fill out the form, be sure to choose “mysql-remote” service module.
    NOTE: Internal Host and External Host will need to be the public IP of the server that has the MySQL instance.
  6. Click “Create”.
    Once that is completed, you will be able to use the “Database” and “Database user” features under “Domain Management”.
