How to login to Monster Panel
Monster Panel is the control panel that we at xByte Hosting offer to its customers to help manage their Windows servers. The goal of this Article is to give instructions on how to login to Monster Panel.
How to Login
When you purchase a Cloud server running Windows, you will receive login information for that server’s control panel. With that login information, you should receive a URL with the following format:
https://web.example-server.com.xbh.servers.monsterpanel.io:1111/
You will then use the login information that is provided to you with your Cloud server order to login to your servers Monster Panel instance.
NOTE: Each Windows Cloud Server will have its own instance of Monster Panel available
