Creating additional Users for RDP
Part 1: Create a New User for RDP
Step 1. Open the “Windows Start menu” and search “Computer Management”.
Step 2. Expand Local Users and groups.
Step 3. Select “Users”.
Step 4. Right-click and choose “New User”.
Step 5. Fill out the user information and click create…
Part 2: Giving user RDP permissions
Step 1. Right-click on the user and select properties.
Step 2. Navigate to the “Member Of” tab and click “Add”.
Step 3. In the empty field type “Remote Desktop Users” and click “Check Names” then “OK”.
Step 4. Click “Apply” and “OK”.
Once you have finished this step, then that user can be used for RDP access.
